MancheKid86 Posted March 29, 2012 Posted March 29, 2012 getting my drive shaft shortened tomorrow, i measured 50" u joint to u joint needed, this is with the slip yolk almost flush with the end of the transfer case, should i make it 49" for flex? (as in axle sliding in towards the x-fer case while crawling?) or should the 50" be good? will the drive shaft only slide out while flexing? input would be great. -Devon
Jeep Driver Posted March 29, 2012 Posted March 29, 2012 Your yoke should have a wear mark where it was riding at the seal originally..........that's from where I measured mine. Yes the yoke needs the flexibility to move in both directions.
Blue XJ Posted March 31, 2012 Posted March 31, 2012 The driveshaft will only slide into the tcase on axle droop, and only minimally. I would position the yoke in the middle of its travel, or even a little further in the tcase and then measure.
