jons87mj Posted February 20, 2012 Share Posted February 20, 2012 is the oil filter adapter bolt the one that goes into the block normal are revers thread thanks Link to comment Share on other sites More sharing options...
jons87mj Posted February 20, 2012 Author Share Posted February 20, 2012 will i tried taking it off like it was a normal bolt it moved just a hair and know the bolt is rounded off :headpop: :headpop: :headpop: does any body know what to do know? Link to comment Share on other sites More sharing options...
ComancheKid45 Posted February 20, 2012 Share Posted February 20, 2012 slightly smaller wrench? Was it a torx head or standard hex head? They are normal thread but can be tighter than a son of a gun! ;) Link to comment Share on other sites More sharing options...
jons87mj Posted February 20, 2012 Author Share Posted February 20, 2012 it was a 5/8 but my 6 point socket made it in to a no point bolt I'm going to try filling the egeds to a 15mm seem to be the next size to fet if not i make to sides flat and use a adjustable renche hope for the best Link to comment Share on other sites More sharing options...
Pete M Posted February 20, 2012 Share Posted February 20, 2012 got a pair of vice grips? did you use any rust penetrant first? Link to comment Share on other sites More sharing options...
jons87mj Posted February 20, 2012 Author Share Posted February 20, 2012 yes but can't get them all the way on and yes still won't come out and it leaks oil now so i have to get it off thanks Link to comment Share on other sites More sharing options...
Pete M Posted February 21, 2012 Share Posted February 21, 2012 how about one of the rounded-off-bolt/nut removal thingies? I'd hate to see you have to drill the dang thing out. :( Link to comment Share on other sites More sharing options...
