SW86 Posted February 11, 2012 Share Posted February 11, 2012 a buddy has tires i can get for cheap but they are 10ply. all ive ever run on is 6 or C load tires. how would those run on an MJ? i figured being E rating they wouldnt get as good sidewall flex and be rough as hell. thoughts? Link to comment Share on other sites More sharing options...
foreman1063 Posted February 11, 2012 Share Posted February 11, 2012 Your assumption is correct, rough and poor handling. Link to comment Share on other sites More sharing options...
FrankTheDog Posted February 11, 2012 Share Posted February 11, 2012 I run 265/75/16 B.F.Goodrich Rugged Trails on my XJ. They work fine. The key is to NOT to run the air pressure high. I run them at 28psi and they handle great. Also, when your towing or carrying a decent load it's nice to have the extra stiffness of sidewall with some extra air in it, say around 35-40 in the rear. If you can get them for a decent price I say run them and experiment with air pressure. TJ Rubicon's run a 245/75/16 with no trouble. Link to comment Share on other sites More sharing options...
foreman1063 Posted February 11, 2012 Share Posted February 11, 2012 TJ Rubicon's run a 245/75/16 with no trouble. True but they run a radial with a 3 ply side wall IIRC, not a bias ply, 10 ply. Link to comment Share on other sites More sharing options...
SW86 Posted February 11, 2012 Author Share Posted February 11, 2012 the tires are a 305/70/16 nitto mud grapplers. they are radials i believe Link to comment Share on other sites More sharing options...
foreman1063 Posted February 11, 2012 Share Posted February 11, 2012 the tires are a 305/70/16 nitto mud grapplers. they are radials i believe Gottcha, I was thinking you said bias but just re-read your post and see that I was mistaken. Link to comment Share on other sites More sharing options...
SW86 Posted February 12, 2012 Author Share Posted February 12, 2012 so i guess I'm good since they're radials? I'm sure itll still be a stiffer ride but nothing like bias tires. Link to comment Share on other sites More sharing options...
foreman1063 Posted February 12, 2012 Share Posted February 12, 2012 so i guess I'm good since they're radials? I'm sure itll still be a stiffer ride but nothing like bias tires. Tryem if they're cheap but that's a stiff tire for a light truck. Let us know how they work for ya. Link to comment Share on other sites More sharing options...
btm24 Posted February 12, 2012 Share Posted February 12, 2012 so i guess I'm good since they're radials? I'm sure itll still be a stiffer ride but nothing like bias tires. Bingo :thumbsup: Brandon Link to comment Share on other sites More sharing options...
