jeepdoggydogB Posted January 27, 2012 Share Posted January 27, 2012 Hello Fellow MJ Addicts, My 21 year old stock starter died and for expedience sake I installed a starter from WPS (World Power Systems) as it was the fastest delivery I could get. I noticed a very different sounding starter when I turn the truck over, it works fine, but the noise is like a cat passing a hairball. Is this common with newer starters? It is so annoying and I paid so little that I am tempted to order the Chrysler replacement starter and shelve this one for an emergency. TIA Dog Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 27, 2012 Share Posted January 27, 2012 Well Joe, I have heard cats passing hairballs (disgusting sounds), but never a starter motor that sounded like that. A unique starter you purchased. :D Back in the day when there weren't cheap "offshore" parts so readily available, we used to have starters, alternators, and generators rebuilt. Sometimes all they needed was a cleanup and a set of brushes, or maybe on open stator rewound, but it's almost always better and more reliable than the offshore junk. There are still a lot of shops around that do this, and it's probably what I would do unless I could find a genuine NOS unit for cheap. Link to comment Share on other sites More sharing options...
jeepdoggydogB Posted January 27, 2012 Author Share Posted January 27, 2012 Well Joe, I have heard cats passing hairballs (disgusting sounds), but never a starter motor that sounded like that. A unique starter you purchased. :D Back in the day when there weren't cheap "offshore" parts so readily available, we used to have starters, alternators, and generators rebuilt. Sometimes all they needed was a cleanup and a set of brushes, or maybe on open stator rewound, but it's almost always better and more reliable than the offshore junk. There are still a lot of shops around that do this, and it's probably what I would do unless I could find a genuine NOS unit for cheap.Thanks Don,My favorite little business like that called Titan Alternators in Napa closed its doors 20 years ago :( There is a place in Berkeley that has a good rep that I am going to get a price from though :D A good NOS from the dealer is $250 see let's see how much it costs to rebuild. Link to comment Share on other sites More sharing options...
txjeeptx Posted January 27, 2012 Share Posted January 27, 2012 I've had a similar problem with big chain stores offshore rebuilt starters not working right. The starter might have had its mounting surface ground on by a sweatshop worker, and now it mounts too close to the ring gear on the flywheel, and the teeth on the starter bottom out in the teeth on the ring gear, making your "hairball" sound. I've shimmed a Motorcraft style starter I used on my 2.5L YJ because of noisy engegement, but I don't think there are any shims made for Chrysler starters. That sweatshop rebuild might also even have an incorrectly sized gear installed on it, so you might compare it with the one you pulled from the Jeep, if you haven't already cashed in the core charge on it. Did you take a look at the condition of the ring gear? They get chewed up over the years of use, and could be a cause of noisy operation, too. When you get your starter rebuilt, make sure to take a look at the ring gear, even though there's not much you can do about it if it looks beat up, since you'd have to pull the trans to replace it. Hope it looks decent, with just minor rounding of the teeth on the leading edge where the starter throws in. Link to comment Share on other sites More sharing options...
jeepdoggydogB Posted January 27, 2012 Author Share Posted January 27, 2012 I've had a similar problem with big chain stores offshore rebuilt starters not working right. The starter might have had its mounting surface ground on by a sweatshop worker, and now it mounts too close to the ring gear on the flywheel, and the teeth on the starter bottom out in the teeth on the ring gear, making your "hairball" sound. I've shimmed a Motorcraft style starter I used on my 2.5L YJ because of noisy engegement, but I don't think there are any shims made for Chrysler starters. That sweatshop rebuild might also even have an incorrectly sized gear installed on it, so you might compare it with the one you pulled from the Jeep, if you haven't already cashed in the core charge on it. Did you take a look at the condition of the ring gear? They get chewed up over the years of use, and could be a cause of noisy operation, too. When you get your starter rebuilt, make sure to take a look at the ring gear, even though there's not much you can do about it if it looks beat up, since you'd have to pull the trans to replace it. Hope it looks decent, with just minor rounding of the teeth on the leading edge where the starter throws in. Thanks txjeeptx,Haven't traded in the old starter yet, the ring gear looked good no abnormal wear, I think you are on to something with the shim. As soon as I get the other one rebuilt I will remove and return this one. Link to comment Share on other sites More sharing options...
flint54 Posted January 28, 2012 Share Posted January 28, 2012 My 21 year old starter bought the farm a couple months ago, and I got a new OEM starter from the dealer same day. Cost me $180, but works like a champ, and I have some confidence it may last the next 21 years, possibly longer than I will. Link to comment Share on other sites More sharing options...
