Backroads Posted January 18, 2012 Posted January 18, 2012 For sale now. Located in pa, 19344 Riddler cover NOT included. Its a 29spline 8.25 from a late model xj. Has and aussie inside. Perches were relocated to fit the MJ spring stance. Shock mounts raised up and both moved to the rear. Has brand new shoes and drums and spring kit. Everything was installed a couple months ago and has less than 2k on it since swapped in. forgot to mention this is 4:10 gears Located in chester/lancaster co PA. Will deliver or meet if reasonable distance. $300.00 Partial trades for 5.5" RE coils.
89 shortbed Posted January 18, 2012 Posted January 18, 2012 What gear ratio? How close are you to the Ohio line? Very interested
FrankTheDog Posted January 18, 2012 Posted January 18, 2012 What gear ratio? How close are you to the Ohio line? Very interested Ashtabula Ohio to Chester PA is about 7.5 hours. Just south of Philly.
89 shortbed Posted January 18, 2012 Posted January 18, 2012 Man that's just too far! Good luck on the sale and its a great deal!
Backroads Posted January 18, 2012 Author Posted January 18, 2012 Forgot to mention this is 4:10 gears!
Backroads Posted February 1, 2012 Author Posted February 1, 2012 U bolts and spring plates are included as well.
agoldxj Posted February 2, 2012 Posted February 2, 2012 I wish you had a matching front d30 with 4:10s!
Backroads Posted February 3, 2012 Author Posted February 3, 2012 I wish you had a matching front d30 with 4:10s! I do but its still under the mj ;) Pm replied
Archived
