specialkeay Posted December 14, 2011 Share Posted December 14, 2011 So I have elimenated the heat vacuum actuator, flushed the heater core (no obstructions) and changed the theromostat and still have not had any change with my heat situation. It blow room tempeture air and on these cold days its just useless. Is there somting that I have missed :fs1: 89, 4.0 Link to comment Share on other sites More sharing options...
cruiser54 Posted December 14, 2011 Share Posted December 14, 2011 Is your heater blend air door opening all the way? Look under the passenger side dash and move the COLD to HEAT control lever back and forth. When moved to HEAT, does the lever hit the stop? If not, adjust the cable clip right there. Link to comment Share on other sites More sharing options...
specialkeay Posted December 14, 2011 Author Share Posted December 14, 2011 It was about a quater inch away so I tighten up the cable and ziptied it to the stop just to be certain. I got to spend the rest of the night with the wife and kids so no time for a test drive let you know tomorrow thanks. Link to comment Share on other sites More sharing options...
carnuck Posted December 22, 2011 Share Posted December 22, 2011 Is it tomorrow yet? Link to comment Share on other sites More sharing options...
cruiser54 Posted December 23, 2011 Share Posted December 23, 2011 Is it tomorrow yet? Gotta be tomorrow somewhere. If the heater door adjustment didn't fix it, I would be suspicious of a faulty or low-temp thermostat. Link to comment Share on other sites More sharing options...
