Preston Posted December 11, 2011 Share Posted December 11, 2011 Any body know what would cause the left turn signal to come on, solid, when I turn my lights on. The front left park light will be off when this is happening but all the other park lights and flashers work. Link to comment Share on other sites More sharing options...
Pete M Posted December 12, 2011 Share Posted December 12, 2011 might be corrosion inside one of the sockets causing a grounding issue. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted December 12, 2011 Share Posted December 12, 2011 might be corrosion inside one of the sockets causing a grounding issue. That's an indication that you have a "problem" with that side light (front or rear). Could be a bulb...but I'd have agree with Pete that you'll likely need to address the socket, up to and including a new socket. I replaced all my sockets when I was building my MJ up, there were just too many issues with each and every socket. The only ones that did not need replacing were the little yellow push in type. Link to comment Share on other sites More sharing options...
carnuck Posted December 22, 2011 Share Posted December 22, 2011 For a "temporary" fix, an EL-12 flasher will still work if only 1 bulb flashes. Link to comment Share on other sites More sharing options...
