Help Identify loose connections please!
Please help identify the loose connections in the two pics. :help: :help:
they are the same connections just different views.
same pic different view
and are any of them supposed to be attached any where.
the orange one comes from a connector toward the front of the engine bay
The red arrow is pointing to the red wire for a under hood light option.
The orange arrow is pointing to the orange wire for AC compressor clutch.
The white arrow points to half of a connector, I think it is the up shift light, manual trans?
The green arrow points to a vacuum line which should connect I think to the vacuum line right beside the red/yellow.
Red yellow arrow / connector, not sure.
The blue arrow points to a vacuum vent check valve.
Where does the black vacuum line with right angle originate?
I have a black and purple that come out of firewall by heater hose. Purple goes to the heater valve. The black makes a connection on the right side and goes up to vacuum football in front bumper.
