JeepcoMJ Posted November 27, 2011 Share Posted November 27, 2011 I just moved from a place with a garage and driveway (and thus the ability to run an extension cord) to an apartment complex. my jeeps all have block heaters...my parking spot is 200 yards from my door, in a high foot traffic area. so. I want to know if there's an efficient (and feasible) way to convert dc power to ac power, then via a timing device control a time period in which the heater would be turned on...all without draining the battery too much for it to start in a 10 or so hour time period. this isn't for any startability issues...I just simply like to get in an already warm vehicle. Thanks, -Pat Link to comment Share on other sites More sharing options...
Thunderbear Posted November 27, 2011 Share Posted November 27, 2011 Are you not wanting an auto start, then? Sounds like that would be easier. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted November 27, 2011 Author Share Posted November 27, 2011 it's a 5 speed, so no. I don't care how good your e-brakes are, you never leave a manual vehicle out of gear when not running. Link to comment Share on other sites More sharing options...
nitroxsteve Posted November 27, 2011 Share Posted November 27, 2011 Check this out. http://www.webasto.us/general/en/html/8352.html Expenseve (cost more than our truck were new) but works great. We use it in heavy equipment no power supply needed. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted November 27, 2011 Author Share Posted November 27, 2011 yeah...i've installed those before. but they are designed to run off diesel, so will not be efficient even if i could get it to run off gasoline. I'm really trying to figure out a way to do this via the 115v block heater. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted November 28, 2011 Author Share Posted November 28, 2011 my thought process is running along the lines of a 12v timing device between the battery and the power inverter. I need to figure out the power draw specs of the heater, and of the inverter, and weigh the difference in order to avoid draining my battery, and decide how long I need to run the system in order to achieve temp. my goal is to at least get the coolant temp. above 55 degrees prior to starting the vehicle. I'm only trying to get it warm, not hot. if needed, I will add a second optima red top in system with a battery isolator so that I can also jump start the vehicle via second battery. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted November 28, 2011 Author Share Posted November 28, 2011 something along these lines http://www.brazix.com/prodfly.asp?ItemP ... QAodYHdpqQ Link to comment Share on other sites More sharing options...
knever3 Posted November 28, 2011 Share Posted November 28, 2011 Engine block heaters draw between 500 and 650 watts of 115V AC energy. It's a lot less efficient to invert DC to AC so you will waste some heat energy doing so. Say if you were to get an inverter rated at a conservitave 1000W because the block heater would be a pure resistive load your battery will die a very short life. Adding a second battery with a 10V automatic cutoff and a primary battery for starting would only add cost because you will still have the constant drain and short life. I would expect in an apartment complex they would not want you running a small gas generator to run your block heater either. They do sell heating pads that you apply directly to the oil pan but again normally to be used with a constant power supply. Do you park in a car port or just out in the open? Link to comment Share on other sites More sharing options...
