OTK steering, warning: rusty's offroad inside.
http://rustysoffroad.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=rustys&Product_Code=OTK01&Category_Code=ste
i know its rusty's and alot of people don't think to highly of them...
but what do you think of the kit's basic ideas,
i could get a shop to build me custom steering with the same ideas for probably a little less money.
anything that would point you away from this kit?
plan on running 33 then 35s after that, has to hold up to big rocks and some mud.
TIA,
-nick
ps. here's some pics:
Personally I do not like Heim joints for the street. Lotsa other reasons, like single shear on this style setup and thats a BIG NO-NO for heims.
That and Rustys "history" is enough for me to not go with this setup.
I know you have read what I have to say about JCR's 1ton conversion. I also know you said your bro has it. Why not go this route?
BTW,
The brown suit guy just dropped mine off today!! Woohoo!!!
CW
RUN from it.... make you a setup like I have on casper, and buy the Goferit set up, and do it on the cheap using 1 ton tre's. The problem with Hiems in general is they don't hold up very well in a dirty enviroment. They tend to wear out quick. If you can't find a pic of Casper on here I think I might have one, just search some of my Post to see how the setup is on it
they have the kit available with TRE's instead of heims.
that was the route i would go, i know ive read that heims die on streets pretty quick. not to mention flexing.
ill search for casper... I'm just looking to have a steering setup that will not cry when i lift her more than 6"
cuase i know inchitis will occur then.
basically just a regular TRE steering with beefy rods and drag link to the knuckle instead of tie-rod right?
thats what the JCR steering is, so i guess ill just run with that, is theer any advantage to running over the knuckle like the rusty's kit?
Heim wear is an issue if you DD it or spend a lot of street time. They'll last 'long enough' in a trail only application. As in you'll probably decide to rebuild the rig before they will actually wear out.
That is providing you run the ones with an insert (teflon or such).
But, for the money you can get some nice chevy 1/2 ton TREs. The ones everybody tries to sell as being 1-ton....
yeah, the kit is available with TREs although i don't know if they are 1/2tons or stocker stuff... here's the quote from rusty's which sounds like they think heims are awesome... i don't like them:
"We use the highest quality 3/4" greasable heims with a 5/8" hole. Score, High Desert, Corr, Scca, just about every type of race vehicle uses heim steering. For those that would rather have tie-rod ends, all of our steering conversions are available with high quality tie-rod ends as well. The quality heim joints we use are stronger than tie-rod ends and if greased regularly should last as long as tie-rod ends, even on daily driven vehicles."
Just the fact that they seem to be trying to convince you how good THEIR heims are raises a flag in my book.
Like Pat already told you, you could run TRE's on top but the JCR pass side TRE will not work. When flipped the taper is wrong. All other TRE's will work fine, you just need to find the application where this taper is on the other side. Maybe BRONCO stuff??? James Duff carries lotsa Bronco goodies!!
Personally I have run this JCR stuff into lotsa rocks but am yet to bend it. I KNOW I CAN, just haven't yet. I am not overly careful of my steering since the JCR install.
CW
It is.. if you have the tools.... RH and LH taps, and the right size DOM, and you can make your own... expect to pay a pretty penny for the LH tap, but if you make say 3 or 4 steering setups.... it would be worth it, or you can buy tubing adapters, and weld them in, and be beefy as hell
