mjeff87 Posted January 15, 2007 Share Posted January 15, 2007 Thought Iâd throw up a little old-school tech for the group. Although most of the component removal I did wasnât absolutely necessary, I was doing some other maintenance and mods at the same time, and the pics are a lot better to see what Iâm describing.  After listening to my timing chain slapping around for the last 30K miles, I decided to replace it over the weekend. Special thanks to Chuck (cmcolfax) for giving me half of his garage to work in :cheers: If anyoneâs thinking about doing this who hasnât done it before, Iâll try to make this as all-inclusive as I can. Feel free to ask any questions if I donât cover everything (or if I left anything outâŚ.I was working solo and taking pics as I thought I should for a good writeup). My MJ is a 2.5L, but both the 2.5 and the 4.0 share the same bottom end, so the procedure is identical for either engine. Your alternator bracket will be a bit different than mine, and I donât have AC so I didnât have to work around AC lines or a condenser, either. YMMV ;)  OK, here we goâŚhereâs the patient, my 87 MJ 2.5L with 174K miles on it, and a slapping timing chain:  Image Not Found Image Not Found   Start by removing the battery, drain the cooling system and remove the radiator (and if you have AC, deal with the condenser somehow):  Image Not Found   With the radiator out of the way, you can see the harmonic balancer bolt that needs to be loosened. At this point, leave the serpentine belt intact (the tension will help hold the balancer stationary while you loosen the bolt):  Image Not Found   Thereâs a couple different ways to break that bolt loose (which I wonât mention), but I prefer this for a quick-and-easy method:   Image Not Found   Break the bolt loose, but do not remove it yet. Now you can remove the serp belt. First, loosen the tension in the belt via the power steering pump (all bolts are ½â hex head, FYI). There are 2 bolts to loosen that hold the pump, one trunion nut that holds the tensioner bolt, and one tensioner bolt you turn counter-clockwise to move the pump toward the engine. Remove the airbox for complete, hassle-free access to these. The two bolts in the back of the pump are these:  Image Not Found  The trunion nut is in the front, at about 7 oâclock:  Image Not Found  And the tensioner bolt is under the pump, pointing toward the driverside fender. Turn it counterclockwise to loosen the pump (you may have to persuade the pump to move if it hasnât in a while):  Image Not Found   Remove the belt. At this point, I also removed the radiator shroud, fan, and water pump pulley for better access to the timing cover. Next step (if you havenât already) is to set the engine to TDC, using the harmonic balancer bolt that you loosened above. Rotate the engine clockwise with a žâ socket until the timing mark on the balancer lines up with the â0â mark on the timing tab on the cover:  Image Not Found   Verify TDC by rotor position. The rotor tip should be pointing directly at the #1 tower on the distributor cap:  Image Not Found   Once you are at TDC, remove the harmonic balancer. Use a balancer puller, like this⌠ Image Not Found   It attaches to the HB and pulls it off the crank snout cleanly and easily. Do not redneck engineer this process, and do not rotate the engine.  Image Not Found  With the HB off, you can see what they are famous forâŚ.they are a two piece construction, with rubber sandwiched inbetween the inner and outer parts, and the rubber starts to migrate out, and start gringing away on the front of the timing cover (not a good thing). Hereâs what mine looked like:  Image Not Found   And this is what the back of the HB looked like. See the rubber ring :cry: ?  Image Not Found   Weâll deal with that in a bit. For now, go ahead and remove the myriad of fasteners that hold the timing cover to the block. The larger studs are 11/16â, and the smaller bolts on the face are 10 mm. There are 4 bolts that hold the bottom of the cover to the front lip of the oil pan, and they are 8mm. I like to keep track of multiple fasteners using a piece of cardboard, like this:  Image Not Found   Finally, you arrive at the timing set. Stop and have 10 beers.  Image Not Found   At this point, if youâve done what I did, you will have roughly a pile of removed parts that looks something like this:  Image Not Found   And your engine bay will look something similar to this:  Image Not Found   Good enough for today, Iâll finish tomorrow:  Image Not Found Link to comment Share on other sites More sharing options...
mjeff87 Posted January 15, 2007 Author Share Posted January 15, 2007 OK, to continue. I cleaned up the timing cover, and the damage from the balancer was minimal (not enough to warrant replacement):  Image Not Found The only difference between the 2.5 and 4.0 timing sets (the parts themselves are identical) is that the 2.5 uses a spring-loaded tensioner. Mine tensioner was shot, causing the clacking sound, and the chain was stretched somewhat. Hereâs the gears and chain with the tensioner removed. Not cool:  Image Not Found   Verify the timing marks on the sprockets are lined up, remove the oil slinger on the end of the crank (the dish shaped thingy) and remove the chain and both sprockets together as an assembly. The cam sprocket is held on with a žâ bolt (use the impact gun again so you donât rotate the engine), but the crank sprocket is pressed onto the crank and is held with a machined keeway. A little gentle prying may be necessary to remove the sprockets. Itâs a good idea to stuff some rags into the oil pan at the bottom front of the block to prevent anything from falling into the pan while you are working/cleaning. Once removed, you will have this:  Image Not Found  At this point, DO NOT rotate either the crankshaft or the camshaft or you will have to reset the valve timing. Lay the old timing set next to the new set, and align the new set exactly like the old. Notice the timing marks on the sprockets (6 oâclock on the cam gear and 12 oâclock on the crank gear):  Image Not Found   Clean off the face of the block and mating surface of the cover while the gears are off, and install the new gears and chain, again as an assembly.  Image Not Found   The crank sprocket is keyed, and the cam sprocket has a small hole machined into the back of it that lines up with a pin (I forgot to get a pic of this, sorry), so the gears can only go on one way. Fiddle around with them until it all lines up, then push the sprockets on alternately, so the chain doesnât bind. Once they are on as far as you can push them, I used a rubber mallet to give each a couple taps to make sure they were seated. Spin the cam sprocket bolt back on with the impact (torque to 80 lb/ft), and reinstall the oil slinger:  Image Not Found  One thing (probably the most important, actually) I forgot to get a pic of is to verify the timing marks by rotating the engine (use the HB bolt in the front of the crank snout again) until the timing mark on the cam sprocket is at 3 oâclock. Once there, stop rotating and count the number of chain pins between it and the timing mark on the crank sprocket. There must be 20 pins (15 pins for a 4.0L per the manual) If you didnât move anything when you took the old sprockets off, and installed the new ones with the chain taught, you shouldnât have a problem. If you donât have 20 pins, you have issues, and youâll have to start all over again :cry:  Got 20 pins? Good. Stop and have a beer or five, then proceed. For us 2.5 guys, install the new tensioner. It is held to the bottom of the block with a bracket held by two boltsâŚto access them, you have to drop the oil pan (which I wasnât going to do ;)) Instead, the tensioner itself pivots on a post inside the front of the cover, easily accessible. It is held by a circlip that you remove and pull the tensioner off the post. Slip the old one and replace with the new one, and reinstall the circlip. Make sure the tensioner is UNLOCKED before you button everything up. Once the tensioner is installed, and the oil slinger is put back on the front of the crank (dish shape facing OUT), you can reinstall the cover.  But first, install a new oil seal on the cover. Tap it in with a large socket (or block of wood) squarely into the cover until it sits flush:  Image Not Found   Install the rubber gasket onto the bottom of the cover. There are little tabs that fit thru predrilled holes to align it and hold it in place (no picâŚsorry I forgot). Make sure both the cover face and the block mating surface is sqeaky clean, apply gasket sealer to both surfaces:  Image Not Found   I use Indian Head gasket shellac:  Image Not Found   Let it tack up a few minutes, install the paper gasket, then install the cover on the engine. Thread all the fasteners finger tight (this is where youâre carboard template comes in handy). Have fun aligning the 4 oilpan-to-cover bolts on the bottom of the cover. Once all fasteners are installed, torque the small bolts to 5 lb/ft and the large studs to 16 lb/ft. Make sure the oil pan rubber gasket is aligned properly or it will leak.  Reinstall the harmonic balancer (make sure the woodruff key is still there to align it). Do NOT hammer it back on to the crank snout....line up the keyway with the woodruff key and push it on as far as you can, evenly. Then, thread the the 3/4" bolt and washer back into the front of the crank and tighten it down. It will draw the balancer back onto the crank as you tighten it down. Wipe some clean engine oil around the sealing surface of the balancer so that the new front seal you just installed doesnât rip when you first start the engine. Verify timing one last time by rotating the engine around until the timing mark on the HB aligns with â0â on the timing tab (TDC) and verify rotor position on the distributor. If you did everything right, it should be pointing to #1.    I didnât take any pics of the reinstallation of everything else, but if you took it off you ought to be able to put it all back together ;) I completed the work with a coolant flush and new radiator hoses (upper, lower, and heater, with new clamps). Donât forget to remove the overflow bottle (if you have an open system) and flush/clean it also). I also changed the oil just in case anything nasty found itâs way into the oilpan while I was working.  Once you get it all buttoned up, fire it up. If it runs, you did goodâŚ.have another beer. If it doesnât, have a beer anyway âcause youâre going to have to rip it all back apart:  Image Not Found   Hope this helps somebody!  Jeff Link to comment Share on other sites More sharing options...
comancheman Posted January 15, 2007 Share Posted January 15, 2007 not in need of a timing chain yet but thanks for posting it I'm sure ill use it in the future Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted January 16, 2007 Share Posted January 16, 2007 Nice job!!! Â EVCELLENT referance!! Â CW Link to comment Share on other sites More sharing options...
88MJay Posted January 16, 2007 Share Posted January 16, 2007 Nice job on the write-up. Link to comment Share on other sites More sharing options...
mjeff87 Posted January 16, 2007 Author Share Posted January 16, 2007 Got some better pics of the tensioner today, to show just how worn out it was :cry: Here it is, assembled as it came off the engine. The little block at the end of the spring starts it's life at the other end of the assembly, up where the little locking handle is on the far left. This thing has gone the whole way to the end of it's adjustment range:  Image Not Found   Here you can see how worn the face of it is, where the chain rides. See the nice, chain-shaped grooves worn into it? They are about 1/4" deep :eek:  Image Not Found  This isn't the best pic, but it shows the wear on the inside, where the snubber block rests against the inside of the tensioner arm. Both surfaces have teeth cut into them (to prevent the snubber from moving backward as the assembly wears...it ratchets it's way up the tension arm as it goes thru it's life. It's hard to see, but the snubber teeth are completey worn away, as are the teeth on the inside of the arm. You can see where the block has been sitting (at the end of it's adjustment range) for the last 30K miles on my engine.....  Image Not Found  Jeff Link to comment Share on other sites More sharing options...
Drahcir495 Posted February 10, 2009 Share Posted February 10, 2009 Wow, this is awesome. Never seen it before. Anyway we can get it moved to the DIY section :dunno: Link to comment Share on other sites More sharing options...
Drahcir495 Posted February 10, 2009 Share Posted February 10, 2009 Ask and it will happen! Thanks :???: :cheers: Link to comment Share on other sites More sharing options...
