Trying to get this tomorrow...
If you left that there with time left in open hours, expect it to be gone.
Stuff like that you have to either take while you are there, or have them set it aside for you to come back. Around here, you'd be fighting guys off with 4 ways just to take a coil off.
Rob
Today I got the Giant coils and spacers "8 inch I'm thinking IDK" plus a aftermarket cable that engages the front axle.
I'm not sure the name of it. It replaces the vacuum line that goes to your front axle... all for $30 exact.
Turns out the lower control arms where 4-links! the top 2 links where missing so I tryed to just get the bottom ones.
I got the driver side off completely off.
Then got the passenger side off the body.
When to take the rest of it off the right front axle
THE LAST BOLT BROKE MY SNAP ON RATCHET!!! omg wtf!
Well just the metal tab that snaps into the socket.
Gears still work fine.
Getting replaces for free thanks to UTI "only thing that there good for".
Very surprised at that, I left the control arms behind.
I'm wanting all new arms anyway.
Got this for FREEEEEEE!!!!
http://www.quadratec.com/products/52435_0X_PG.htm
:drool: ... what is it with people putting the grille upside down? :doh:
lucky, my best find was a cherokee D44
I swear that grill thing was something the dealer did when the jeep went in for work. Almost EVERY RENIX and early 90s Jeep XJ/MJ I come across, has the grill in upside down.
Nice find!
BTW Is that an aluminum wheel somehow welded to a steel wheel???
The wheels that are bolted to the axle?
No, its not welded. The only wheels that are welded are the ones that are holding the axel.
When I felt the XJ, i had all 4 33" tire with the wheels under the front bumper holding it up.
I had to use a giant A frame engine hoist to lift the XJ up to get at the suspension.
Probably tipped over by now. :peek: I didnt do it... lol
My point was you can't weld aluminum to steel without special procedures, and even then it is a very brittle joint. I hope it just looks like an aluminum wheel in the pic. If not don't get under that Jeep!
hey not to sound like a jerk but what special procedures? to my knowledge there isnt any it can't be done period.
