acfortier Posted October 22, 2011 Share Posted October 22, 2011 Hey all, took out my interior, and while doing so, accidently knocked off this spring that was connecting the clutch pedal to something. Anyone have any idea? Or a picture of where the spring connects to? That'd be the easiest way for me to see. I have the BA10/5 tranny. Link to comment Share on other sites More sharing options...
64 Cheyenne Posted October 22, 2011 Share Posted October 22, 2011 Don't believe there is a spring. The clutch returns to top of its travel from the spring in pressure plate via hyd fluid. Link to comment Share on other sites More sharing options...
jimoshel Posted October 22, 2011 Share Posted October 22, 2011 There is no spring for the clutch pedal. There is one for the brake pedal. It hooks into a hole near the top of the arm and to the pedal mounting bracket. Link to comment Share on other sites More sharing options...
acfortier Posted October 22, 2011 Author Share Posted October 22, 2011 :hmm: I think I am going crazy... :nuts: Thanks! I'll check and see if there is one there. Link to comment Share on other sites More sharing options...
MJRemi Posted October 23, 2011 Share Posted October 23, 2011 Mine has a spring. I noticed my clutch pedal was about 3/4 inch higher toward the seat than the brake pedal and discovered the spring was hanging from the pedal rod. It also had about 3/4 of play. I didn't know where it attached on the other end so I just looked around and found a nook on a nearby bracket that would keep tension on the spring. Now it sits even with the brake pedal and has no play. Link to comment Share on other sites More sharing options...
