will an exhaust for a cherokee fit on my comanche i have holes all in it and i plan on just getting a hole new one well from a pull a part from the manafold back will it fit ???????
NO short answer but if you chop it off right behind the muffler it SHOULD be good. The wheel base is shrter on a XJ so it don't line up right.
Cole
Down pipe, catalytic converter and muffler are the same as the XJ (if the XJ has the same engine). The tail pipes are different. Dunno where you live, but it's against Federal law to sell a used catalytic converter, so I don't really think you're going to get an entire system. Given that you're looking at buying the cat new, I would recommend buying new. A Walker stock replacement muffler from Auto Zone costs $25 and has a lifetime warranty -- they replace it free even if you mangle it on rocks. With a deal like that, why fight with rusty, used parts? Stock tailpipes are not that expensive from the chain stores, either.
My down pipe was like 26 bucks shipped from Q-tec, and Eagle is right about the Cat... they are cheap easy to get. If you were closer I would sell you one of the 4 manifolds I have in my garage...
