Incommando Posted September 15, 2011 Share Posted September 15, 2011 The 231J I got for my 4wd conversion is a later style with a "boot" on the rear output as opposed to a metal "cone." Will this cause me any issues? Thanks Link to comment Share on other sites More sharing options...
Geonovast Posted September 15, 2011 Share Posted September 15, 2011 It will affect driveshaft length, but that shouldn't be an issue if you haven't already located a rear driveshaft/had yours shortened Link to comment Share on other sites More sharing options...
Garvin Posted September 16, 2011 Share Posted September 16, 2011 The older style is actually a bit better as it gives support to the yoke with the longer tail shaft housing. If you plan on lifting the Jeep later on, it will also let you lift it higher without any vibes. Another advantage is that you can get a stock drive shaft to fit your Jeep, assuming you can find one in the junkyard. Link to comment Share on other sites More sharing options...
Incommando Posted September 16, 2011 Author Share Posted September 16, 2011 Thanks for the info......I'll have to have the rear shaft cut down anyway so I'll just go from there Link to comment Share on other sites More sharing options...
JeepcoMJ Posted September 16, 2011 Share Posted September 16, 2011 i've never had issues with the newer sealed output shafts and "no extra support". actually, I find that to be a fairly moot point. just remember this....it's a sealed output...you can blow your rear ujoints on your driveshaft, remove it, and drive home in 4wd without losing fluid. Link to comment Share on other sites More sharing options...
mjeff87 Posted September 16, 2011 Share Posted September 16, 2011 been running one in mine for the last 2+ years with no problems. Actually ran it in 4H (FWD) a bit until I got a rear shaft cut to size. Just pull the electric speedo pickup out and swap in your old one, good to go. Jeff Link to comment Share on other sites More sharing options...
Geonovast Posted September 16, 2011 Share Posted September 16, 2011 How does the older style provide "extra support"? All it's doing is moving the seal back further so that it has to seal against the yoke itself. It's not actually holding the yoke up. Link to comment Share on other sites More sharing options...
