comanchekid Posted September 5, 2011 Share Posted September 5, 2011 ok so my tail lights are broken so i wanted to make some led ones... what i got is 3 lead leds for the stop brake and turn and i got another "driving Light" led for the reverse lights but I'm not to sure how to hook them up because the stock xj used a 3 light system verses me using a 2 light system....i tried wiring them a couple ways but won't work.... this is how i tried first What happens is when u turn on the turn signals it acts as if the emergency flashers are on... so then i tried this (just removing on major on one side) Then everything works fine like that but when the brake lights are on i get no blinker??? any help again is greatly appreciated thanx Justin Oh someone had mention a foreign to American tail light module or something? no clue where to find that i call some auto parts and they have no clue Link to comment Share on other sites More sharing options...
JeffN Posted September 5, 2011 Share Posted September 5, 2011 you need an electronic flasher unit, LED lights won't have the amp pull to start the standard flasher flashing Link to comment Share on other sites More sharing options...
Eagle Posted September 5, 2011 Share Posted September 5, 2011 you need an electronic flasher unit, LED lights won't have the amp pull to start the standard flasher flashing That may be part of the issue, but he's going from an XJ setup, that had separate, amber lights for turn signals, to an MJ style that blinks the brake lights for turns. The old/early XJ Wagoneers also did NOT use dedicated amber turns, and there was an entire tail end sub harness that was different in the XJ Wagoneers than what was in the XJ Cherokees. The simplest solution now would be to get a "logic box" such as what's used to run standard, small trailer (4-wire) lighting off an XJ. Connect the logic box to the chassis harness per the instructions, and run your LED units off the output (trailer) side of the logic box. Link to comment Share on other sites More sharing options...
comanchekid Posted September 5, 2011 Author Share Posted September 5, 2011 perfect thank you :) now the question is there are seperate wires going to each tail light on the xj... do i need to go back further before the wires split and wire it in there or is there a different way? Link to comment Share on other sites More sharing options...
comanchekid Posted September 9, 2011 Author Share Posted September 9, 2011 . i got a converter and wired it in and nothing...?? maybe i need more grounds? the convert wires are white=ground red=brake green=right turn yellow=left turn brown= park/tail so i wired it where i cut off the bulbs with all the grounds into one on the frame.. i took both the majors (brake i believe) and wired them to the red wire then the right turn wire to the green... left to the yellow...and took both minors(running lights) and hooked them to brown But i get nothing also the reverse lights are not hooked up but the grounds are... i don't know if that helps any but I'm kinda lost what to do someone help Link to comment Share on other sites More sharing options...
Motion Offroad Posted September 9, 2011 Share Posted September 9, 2011 When I did the LED's on my XJ I learned a few things. Not sure if your using a similar setup as I did. I used 1 light for stop/turn, and 1 light for backup. I used a draw-tite trailer harness that plug in-line with my factory wiring. I didn't have to cut any wiring this way and it simply was a "plug & play" setup. It converts it to a 3-wire setup to a 2-wire setup so I could use 1 light for stop/turn. The LED's simply run off the new harness. I also had to use an electronic flasher. The part number from my local auto-supply store was EL12 (2 prong). Hope that maybe helps... -Adam Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 9, 2011 Share Posted September 9, 2011 Here's how I wired mine. LEDs in the tail lamps, 3rd brake light, and electronic flasher. Link to comment Share on other sites More sharing options...
comanchekid Posted September 9, 2011 Author Share Posted September 9, 2011 all of my grounds are connected to one should i make more grounds? Link to comment Share on other sites More sharing options...
comanchekid Posted September 13, 2011 Author Share Posted September 13, 2011 bump? Link to comment Share on other sites More sharing options...
comanchekid Posted September 21, 2011 Author Share Posted September 21, 2011 ok so i got them working ended up making my own "module" out of 4 relays wired together the only problem is when the blinkers are on...i get a smaller blink on the opposing side???? everything works fine except for that Link to comment Share on other sites More sharing options...
