Blue88Comanche Posted August 23, 2011 Posted August 23, 2011 I am in the process of swapping from my ba10 to an ax15 and i am told that the ax15 sits 1 inch lower than the ba10.. i can't seem to find the cross member i need for my MJ but i found a 1 inch crossmember drop an rustys offroad website. my question is if i use the 1 inch drop will that mess up my drive angles for the front wheels? my jeep is at around 1 to 3 inch above stock thanks
Pete M Posted August 25, 2011 Posted August 25, 2011 if you combine a AX-15 with a peugeot crossmember with a 1" crossmember drop it'll all balance out to normal. :thumbsup: don't buy a kit if you can make one. it's just 2 pieces of metal with holes in it. nothing complicated. or better yet, ask in the classifieds since frequently MJ kits mistakenly come with them and the owners don't use them.
HOrnbrod Posted August 25, 2011 Posted August 25, 2011 Yes, simple to make. Made one in about an hour out of a piece of 1" square tubing scrap cut and drilled to size when looking for ways to get rid of some annoying driveline vibes. Unfortunately that wasn't the cause of the vibe problem.
