JeepNewb Posted August 22, 2011 Posted August 22, 2011 Anyone have any advice where i can get the sending unit with the float? Or is this a complete unit with pump? Also, what would be good to use to clean out the inside of my tank? I just dropped the tank today so i could clean inside/outside and paint the outside of the tank and to also get to the undercarriage in that area for painting as well. I also need to address an issue with my fuel gauge not working............sometimes i have seen the gauge "float" back and forth even though i have a full tank of gas. I was told this was the sending unit from the dealer i got it from.
tallon2064 Posted August 22, 2011 Posted August 22, 2011 I may be able to help you out with a sending unit, but I need to know what size tank you have and if your truck is a renix or a ho motor.
JeepNewb Posted August 23, 2011 Author Posted August 23, 2011 It's an 18 gallon tank and i'm not sure on the engine. How can i tell??
Geonovast Posted August 23, 2011 Posted August 23, 2011 It's an 18 gallon tank and i'm not sure on the engine. How can i tell?? 86-90 Renix 91-92 HO
