Geonovast Posted August 15, 2011 Posted August 15, 2011 I don't know how, but both of those stupid things managed to jump ship. The gate still latches, but I'm leary of opening it, and only do so when I have to. The hardware stores around here suck and I haven't been able to find a bolt even close.
Backdraft Posted August 15, 2011 Posted August 15, 2011 The bolts that hold the latch itself in place? I think I have those from my donor. Going to the property tomorrow, I'll pull em for you while I'm there
Geonovast Posted August 15, 2011 Author Posted August 15, 2011 Yeah, the two that go in from the bottom of the gate into the latch. I'm still baffled as to how they went missing.
Backdraft Posted August 18, 2011 Posted August 18, 2011 I've only got one of them. When I checked, the other was missing. I guess those things backing out is a common problem?
Geonovast Posted August 18, 2011 Author Posted August 18, 2011 I've only got one of them. When I checked, the other was missing. I guess those things backing out is a common problem? Must be. When I get new ones I'm definitely putting loctite on them.
Geonovast Posted June 5, 2012 Author Posted June 5, 2012 It's becoming urgent I get ahold of some of these. My hatch won't open at all now, I'm 99.99% sure why, I can get it to open by getting through the inner trim, but I really need these bolts before I go messing with it, in case I can't get it to latch again.
HOrnbrod Posted June 5, 2012 Posted June 5, 2012 If I crossed the correct bolts (2), they are Mopar p/n 6502623 and the specs are M8x1.25x23. These metric bolts should be available at any Fastenal or similar.
Geonovast Posted June 9, 2012 Author Posted June 9, 2012 If I crossed the correct bolts (2), they are Mopar p/n 6502623 and the specs are M8x1.25x23. These metric bolts should be available at any Fastenal or similar. Awesome, I'll hit up the hardware stores in the morning after work. No Fastenals around here, but there's a pretty big hardware store just up the road. Thanks Don.
jimoshel Posted June 10, 2012 Posted June 10, 2012 Cory, If you haven't found them screws yet send me yer addy. They'll be in the mail Mon Morn.
