jerseyjeepin856 Posted August 12, 2011 Share Posted August 12, 2011 my brake lights and blinkers are not working all other lights work i just replaced the bulbs and theyre still not working i don't know too much as far as jeep electrical problems so any help is appreciated Link to comment Share on other sites More sharing options...
Pete M Posted August 12, 2011 Share Posted August 12, 2011 do the front blinkers work? Link to comment Share on other sites More sharing options...
JeffN Posted August 12, 2011 Share Posted August 12, 2011 Do they light up and just not flash? Is it the same front and rear? Many, many things could be wrong, we need more information to be able to help. Link to comment Share on other sites More sharing options...
JeepNewb Posted August 13, 2011 Share Posted August 13, 2011 Do the flashers work? I had the same issues with mine, got all my lights working except the blinkers..........but my flashers work so I'm thinkin the column switch could be something to look at. I'm planning to replace it on mine soon. Link to comment Share on other sites More sharing options...
Pete M Posted August 13, 2011 Share Posted August 13, 2011 the flashers and turn indicators run through separate flasher units. swap them with each other and see what happens. :thumbsup: Link to comment Share on other sites More sharing options...
JeepNewb Posted August 13, 2011 Share Posted August 13, 2011 the flashers and turn indicators run through separate flasher units. swap them with each other and see what happens. :thumbsup: Replaced both flashers actually and same result. Link to comment Share on other sites More sharing options...
jerseyjeepin856 Posted August 14, 2011 Author Share Posted August 14, 2011 do the front blinkers work? the front blinkers do not work i checked my fuses they were fine there was also some bondo looking crap all over where the bulbs go in i don't know what that stuff is also my flashers don't work either Link to comment Share on other sites More sharing options...
STERLING STINGER Posted August 14, 2011 Share Posted August 14, 2011 Headlight switch is what id replace first. Imho Paul Link to comment Share on other sites More sharing options...
