MancheKid86 Posted July 10, 2011 Share Posted July 10, 2011 replaced my o2 sensor, still running really rich, black smoke + smell of fuel at the end of my exhaust, what else could it be? Link to comment Share on other sites More sharing options...
JeffN Posted July 10, 2011 Share Posted July 10, 2011 check fuel pressure, regulator could be bad Link to comment Share on other sites More sharing options...
Eagle Posted July 10, 2011 Share Posted July 10, 2011 MAP sensor Link to comment Share on other sites More sharing options...
MJCARENA Posted July 10, 2011 Share Posted July 10, 2011 Bad injector, stuck open. Pull the electrical connector off an injector. Should notice the engine misses. If it misses put it back on and try the next one. If the engine doesn't miss, then the injector is most likely bad. Just a possibilty. You could also pull the sparkplugs out and see if any are fouled. Link to comment Share on other sites More sharing options...
tugalo Posted July 10, 2011 Share Posted July 10, 2011 If you used a universal O2 sensor that you have to splice into the existing harness, the black wire is the output to the computer, not ground as you would think. Link to comment Share on other sites More sharing options...
MancheKid86 Posted July 12, 2011 Author Share Posted July 12, 2011 MAP sensor :thumbsup: Link to comment Share on other sites More sharing options...
