knever3 Posted July 9, 2011 Share Posted July 9, 2011 I don't like OE shifter linkage on my 241 transfer case so before do my 4wd swap I need to order a linkage. Which one is the best between these two? I want someone that has used one before to give me some feedback. Here are the ones I am referring to. Website for info: http://www.novak-adapt.com/catalog/kit_sk2x.htm Link to comment Share on other sites More sharing options...
Motion Offroad Posted July 9, 2011 Share Posted July 9, 2011 We've used the original one (SK2X) before and it works well. I never knew they even had the cable one; must be fairly new... Link to comment Share on other sites More sharing options...
Limeyjeeper Posted July 9, 2011 Share Posted July 9, 2011 I have the cable linkage attached to a 242 in my Eliminator. It works really well once you adjust it correctly which is a little tricky. Certainly better than the stock monstrosity. If you want to see a pic of it installed would be more than happy to snap one for you. It also allows you to keep the stock lever. Link to comment Share on other sites More sharing options...
knever3 Posted July 9, 2011 Author Share Posted July 9, 2011 That would be great!! Link to comment Share on other sites More sharing options...
Limeyjeeper Posted July 13, 2011 Share Posted July 13, 2011 Pics http://www.printroom.com/ViewAlbum.asp? ... _id=228968 Link to comment Share on other sites More sharing options...
knever3 Posted July 17, 2011 Author Share Posted July 17, 2011 Thank you, I bought the cable one, it should be here tomorrow. Thanks for the pics! Link to comment Share on other sites More sharing options...
JeepcoMJ Posted July 18, 2011 Share Posted July 18, 2011 a threaded rod and YJ shift arm with two heim joints would net pretty much the same results without having to modify anything in regards to your shifter handle, and can be done for under $15. way cheaper. Link to comment Share on other sites More sharing options...
