sinkrun Posted June 18, 2011 Share Posted June 18, 2011 Will 2000 grand Cherokee front springs fit on my Comanche and will they add any lift? Link to comment Share on other sites More sharing options...
btm24 Posted June 19, 2011 Share Posted June 19, 2011 It will fit but it depends on alot to find Out how much lift. V8? If so depending on what V8 it had, for how much lift. Also used and new will give different amounts of lift. For the most part you might get an inch or so of lift if it was a V8. Brandon Link to comment Share on other sites More sharing options...
shelbyluvv Posted June 19, 2011 Share Posted June 19, 2011 It will fit but it depends on alot to find Out how much lift. V8? If so depending on what V8 it had, for how much lift. Also used and new will give different amounts of lift. For the most part you might get an inch or so of lift if it was a V8. Brandon :no: A 2000 Grand Cherokee is a WJ. The front coils are much bigger than a T,Z,X,MJ coil. They will not fit in the MJ coil buckets. You want to find 93-98 Grand Cherokee front coils. They will give you about 1 1/2"-2" depending on how worn out they are. Link to comment Share on other sites More sharing options...
btm24 Posted June 19, 2011 Share Posted June 19, 2011 I'm sorry I thought it was up to 2000 that was good and 01 on up to 05 was the WJ and then the WK... My bad sorry for giving the wrong info :oops: Brandon Link to comment Share on other sites More sharing options...
shelbyluvv Posted June 19, 2011 Share Posted June 19, 2011 I'm sorry I thought it was up to 2000 that was good and 01 on up to 05 was the WJ and then the WK... My bad sorry for giving the wrong info :oops: Brandon ZJ = 93-98 WJ= 99-04 WK=05-10 WK2=11-current :thumbsup: Link to comment Share on other sites More sharing options...
mj Mike Posted June 19, 2011 Share Posted June 19, 2011 With UpCountry suspension package? Link to comment Share on other sites More sharing options...
shelbyluvv Posted June 19, 2011 Share Posted June 19, 2011 I have seen people get 1"+ out of standard V8 ZJ coils and others get 1" or less out of UC coils. I guess it all depends on the mileage of the donor. :dunno: Link to comment Share on other sites More sharing options...
sinkrun Posted June 19, 2011 Author Share Posted June 19, 2011 A local (Across the street) guy is parting the 2000 with 56k and I was hoping they would work. Is there anything else I should look for from it? Link to comment Share on other sites More sharing options...
mj Mike Posted June 19, 2011 Share Posted June 19, 2011 steering & sway bar! Beefyer then stock :hmm: ? sorry i was thinking of ZJ :idea: http://www.4x4wire.com/jeep/tech/brakes/xj_wjbrakes03/ Link to comment Share on other sites More sharing options...
tbrand Posted June 20, 2011 Share Posted June 20, 2011 Snag the front control arms, if you have equipment/inclination to grind the metal bushing insert down a bit. Link to comment Share on other sites More sharing options...
