Rebelfish99 Posted May 29, 2011 Share Posted May 29, 2011 I'm working on restoring my 86 Turbo Diesel and I'm having a very tough time finding parts for the motor. I know its a renault 2.1 but I can't seem to match any parts from the same year(s) renault put that motor in their cars. I really need a timing belt, and a new vacumn pump gasket. If anyone knows where I can find parts for my MJ, I'd appreciate it. Link to comment Share on other sites More sharing options...
Automan2164 Posted May 29, 2011 Share Posted May 29, 2011 Try a Winnebago dealer... They put the 2.1 in the Lesharos too, and one of the few remaining places that might have the parts. Rob Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 29, 2011 Share Posted May 29, 2011 Here's a list of Lesharo repair centers in the US and Canada. Some of these guys can help you: http://www.lesharo.co.uk/Technical/RepairCenters.pdf Link to comment Share on other sites More sharing options...
whowey Posted May 30, 2011 Share Posted May 30, 2011 When I was looking at XJ diesels these were the folks I talked to about the motors... http://www.winnebagoparts.com/about-renault.php Link to comment Share on other sites More sharing options...
JeepcoMJ Posted May 31, 2011 Share Posted May 31, 2011 so far as i know, i own the last 3 comanche diesel timing belts that could be had in the states, and none of them are going anywhere (proud family diesel mj owners...plan to keep it around). There are cross-compatible belts out there, but it's going to be tough to find. in the meantime...don't even start that truck until the belt is replaced. and if the belt was bad when you got it, then inspect your valve train...rockers for cracks/breaks, and valves for bends, and cam for bad lobes. -Pat Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 31, 2011 Share Posted May 31, 2011 2.1 TD timing belt equivalent part numbers: TB156 AE TB143 AE TB966 AUTO-DELTA BTB1033 BALCO 1987949033 BOSCH 1987949471 BOSCH T0663544 CHRYSLER / JEEP (OEM) CT522 CONTITECH 94196 DAYCO 148SP254 DAYCO 94328 DAYCO FTB3344 FIRSTLINE 5040 GATES G1280 GOODYEAR VTB140 MOTAQUIP PMTB35 POWERTRAIN PMTB35 POWERTRAIN QTB143 QUINTON HAZELL 7700663544 RENAULT (OEM) GTB1040 ROVER GROUP (OEM) UTB3544 ULTRAPARTS GTB1040 UNIPART (OEM) VT143 VEGEM Search. Link to comment Share on other sites More sharing options...
Rebelfish99 Posted June 2, 2011 Author Share Posted June 2, 2011 The belt is original I'm guessing, I have all the paperwork from the orginal owner and the 2nd, (I'm the third!!) and nothing says a timing belt replacement, but it only has 120K on it. The belt is in OK shape but as for now the MJ sits in the side yard and only gets run on the weekend. I have antique tags on it but I don't drive it around because of the notorious bad drivers in this area. Thanks for the help guys. Link to comment Share on other sites More sharing options...
