86FUBAR Posted December 26, 2006 Share Posted December 26, 2006 http://pic60.picturetrail.com/VOL1664/7555959/14323910/216343924.jpg the bumper is made of 2X4 3/16 wall mild steel and has a 2in recever on it . i originally made D shackle mounts outa some round stock but realized they were very ugly After i welded them on . so i cut those off and welded a set of trailer shackles on and put in a couple of 2in popin back up lights , the bumper is atached via some 2in angle and some flat bar . whata think Link to comment Share on other sites More sharing options...
86FUBAR Posted December 26, 2006 Author Share Posted December 26, 2006 Link to comment Share on other sites More sharing options...
86FUBAR Posted December 26, 2006 Author Share Posted December 26, 2006 it aint WORKING :mad: Link to comment Share on other sites More sharing options...
Rokhound Posted December 26, 2006 Share Posted December 26, 2006 your missing the at the end i think Link to comment Share on other sites More sharing options...
86FUBAR Posted December 26, 2006 Author Share Posted December 26, 2006 i did it like befor and it worked now it aint Link to comment Share on other sites More sharing options...
sinnaevd Posted December 26, 2006 Share Posted December 26, 2006 edit: no idea why its not working? but thats what it suppose to look like lol Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted December 26, 2006 Share Posted December 26, 2006 sinnaevd said: edit: no idea why its not working? but thats what it suppose to look like lol hehe Rob saves the day. you had a final space between the ending img and the .jpg look carefully at your original post sin. Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted December 26, 2006 Share Posted December 26, 2006 86FUBAR said: hears the rear slider i bent up for the rear bumper , i thought this up after i hooked a corner and riped the old bumper off on a rock. its welded to the frame and sticks out a bit so i can attach the rear of my exo to it when i make it. the bumper is made of 2X4 3/16 wall mild steel and has a 2in recever on it . i originally made D shackle mounts outa some round stock but realized they were very ugly After i welded them on . so i cut those off and welded a set of trailer shackles on and put in a couple of 2in popin back up lights , the bumper is atached via some 2in angle and some flat bar . whata think Link to comment Share on other sites More sharing options...
jared Posted December 26, 2006 Share Posted December 26, 2006 welds look good, i like it Link to comment Share on other sites More sharing options...
86FUBAR Posted December 26, 2006 Author Share Posted December 26, 2006 dude i tried every thing i could think of (which isnt much), but i still don't under stand antidisestablishmentarianism ur talking bout /pleas explain, besides i don't want to post a link to the picture like in the original post i want to post the pictures WHAT HAPPENED and how do i not do it again. Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted December 26, 2006 Share Posted December 26, 2006 86FUBAR said: dude i tried every thing i could think of (which isnt much), but i still don't under stand antidisestablishmentarianism ur talking bout /pleas explain, besides i don't want to post a link to the picture like in the original post i want to post the pictures WHAT HAPPENED and how do i not do it again. you had your links so long that they wrapped down to the next line.. nobody noticed this > ................................^ right there... notice the space? thats what it was, except your link was like this img]httpblaf.goof.abcksajdflk;sfd;ljksafdlksafdasdfsdfsdfsdfsadfsadfsdfsdff [/img] there is a space between the last f and the closed image tag. to eliminate this error... open notepad.. fully type your link like this heep://www.servname.blah.com/piccy.jpg[/img} (with proper image tags of course) turn off word wrap. just copy-paste the link into the post window > perfecto links every time. Link to comment Share on other sites More sharing options...
Twisty Posted December 27, 2006 Share Posted December 27, 2006 i like the idea of the tubing protecting the bottom of the bed. did you trim anything off of the bed to make it look like that? Link to comment Share on other sites More sharing options...
86FUBAR Posted December 27, 2006 Author Share Posted December 27, 2006 I did cut the bottom off the sides of the bed just below the body line because when the bumper got ripped off it mushed the bottom corner as u can see in the side shot under the tail light (the rust spots) . the real b*@$£ of it is i was going to cut it off the week before it got busted but didnt, lazy i guss. it sure helped with the ground clearence issue alot once cut, now i aint gota worry bot that any more. Link to comment Share on other sites More sharing options...
Twisty Posted December 27, 2006 Share Posted December 27, 2006 86FUBAR said: I did cut the bottom off the sides of the bed just below the body line because when the bumper got ripped off it mushed the bottom corner as u can see in the side shot under the tail light (the rust spots) . the real @#$% of it is i was going to cut it off the week before it got busted but didnt, lazy i guss. it sure helped with the ground clearence issue alot once cut, now i aint gota worry bot that any more. once i get my welder, I'm going to do that and build a bumper. Link to comment Share on other sites More sharing options...
86FUBAR Posted December 27, 2006 Author Share Posted December 27, 2006 post some pics of it when ur done. also make sure u get a 250amp welder and not a little penut welder or ul be sory. Link to comment Share on other sites More sharing options...
