Front coils. TJ vs XJ(MJ)
Ok, so searched a little and not getting the exact info I want.
Lets use a 6 inch lift spring for example. (same brand, considering some are different rates, and colors(lol)
Is there any difference at all between a TJ and XJ lift coil. (spring rate, height, size, lift you will get on a MJ comparitivly to there proper vehicle application, etc, etc.)
I know answers to a couple of the questions but figure since I'm throwing this post up we might as well discuss every aspect of the question.
Cheers, Jason
Ok, so does anyone know what brands make specific coils for XJ/MJ that are the proper rate, and what companys throw them all together as the same?
Basically what brands have the appropriate spring rate for our MJ's. This could make a big difference in performance depending what brand you buy. (especially if your running sway bar eliminators rather than lets say a Anti-rock.
