'92 found
  • 1 month later...
Pristine and perfect G, as always. You are starting to piss me off. No, I take that back. You pissed me off a long time ago. No way I can keep up. :cheers:
Seriously though, it's absolute correct and beautiful work. But I can't imagine you ever taking that gorgeous 92 anywhere you'll need to use 4WD. She's too pretty.
True Don -- the most this 4wd will probably see is Tahoe snow. Main reason for the conversion (other than I wanted another MJ 4x4 just because) is to see the behind-end of an RV. You can see the bottom side of an RV tow bar in my front suspension photo. Can't tow a 2wd 5-speed for more than 100 miles w/o doing damage to the transmission...hence the 4wd for the "neutral". My only other 4x4 is my work in progress '89. My 2 XJ's are both 2wd.
