Paint job time Bed question
So I am about to get ready this weekend and strip the Mj down for some new paint...... can the bed be just lifted off with out pulling the tank? also whats some opinions on types of paint??? I was going to go with an acrylic enamel
I just pulled my bed off today,Gas tank has to come off.Also parking brake cable bracket,spare tire hanger and exhaust hanger,and some wiring.Take your tailgate off before you pick the bed up or it will be extra heavy in the back(ask me how i know).have fun
I only removed the tank and parking brake junction. Its not much work.
Tank:
- Spray J hooks with PB Blaster
- Disconnect fuel lines and wiring from pump
- unbolt J hooks and let tank down slowly
- while down there trace bed harness to a junction point and disconnect
Parking brake block:
- spray bolts going into bottom of bed with PB Blater
- Remove bolts and let block assembly hang
Spare tire winch and exhaust hanger are bolted to the frame.
Acrylic enamel single stage might be the most economic and simple for a home brew job, But base coat clear looks the best and gives you time to correct sins in between the base and the clear application . Good quality base clear is not like the crap they use at the factory and will hold up better. And gives you a deep shine.
Just my 2 cents worth
Single stage Arcylic enamel is the cheapest for home use and will also give the lowest quality results.
Urethanes will be better for smell and spray, but slightly more expensive.
Base clear will give you the best result with the least amount of work. Better paint means a better spray.
