Brake lines
Want to replace all my brake lines over the next week, couple of ?s. I was thinking about deleting the rear proportioning valve completely, as I'm not sure if it was quite working (my brakes seem waaaay too soft even after I bleed them the RIGHT way...) I bookmarked the other thread that has each of the diagrams, so I was thinking about just plugging the hole in the front valve and deleting that extra line. What do you guys recommend? Also, how much brake line should I get? Is it worth it for me to splurge and buy stainless steel? What do you use to plug the valve up front?
