lift shackles?
So after adding my spare, bumper, hitch and spare parts in the toolbox, it appears my rear is slightly sagging. Does anyone make shackles that will regain the ride height lost from all this weight? I'm looking for an inch or two.....
the longer shackles are only good for maybe an inch of lift. You need a shackle to be 2" longer than stock for each inch of lift and stock ones aren't exactly short.
also keep in mind while shopping, XJ shackles are shorter than MJs and so ones designed to lift an XJ may not be much longer than your current ones.
