Does anybody make rear shock hoops for an MJ? I'd like to raise the upper shock mount for some longer travel shocks. I have a tube bed so plenty of room above the frame. Might be easier and cheaper to just make some myself.
as far as i know there is nothing to relocate the upper shock mount on the market for MJ's
you got it, your going to have to fab some thing.
sounds like a nice build!
what type of shocks you trying to mount?
What is a shock hoop? Not a BPE or adapter?? What does a shock hoop do??
it relocates the upper shock mounts usually through the bed.
Designed to give you more travel and increased ground clearance with no binding on the shocks
T&J makes this for the XJ
1990, 4.0, AX-15, NP-231 SYE, Carolina Driveshafts, D30, 8.8 Explorer, 4.10's with Lock-Rites, 6" long arm, 35" KM2's
Some pictures from Uwharrie this past weekend
