Is It Going To Start Or Not
Comanche worked A1 until today. Started as usual. Ran great as usual. Stopped at the hardware store. When i came out NO GO. Twenty minutes of cranking on & off IT STARTED. I never done nothing. Now it's home and NO GO again. I can hear the fuel pump. :dunno: Guess i need to check for spark. Any other ideas what to check? :Canadaflag:
You'll see a little wire harness come up from the drivers side rear of the engine and connect on top of the intake manifold, that comes from the CPS. Try to unplug and plug it (as said before) but it sounds like it's going bad. When they first start going bad, they will work perfect when cold but won't start when hot (first hand experience on that on my '90 XJ with the 4.0L).
