Chevy shackles
Not positive about the 2" lift on a Cherokee, but the 3/4" on a Comanche is from personal experience on both of my Comanches. I installed a set on the trail rig, and recently I removed a set from my DD.
And for the math:
The shackle is only ~2" longer than a Comanche shackle. That would lift a Comanche 1" IF the axle was centered on the spring. But it isn't; it's closer to a 40/60 split. That would give you 0.8". And then the angles of the spring and the shackle come into play and it gets real tricky.
Simple tape measure to the rescue: 0.75" give or take 1/8.
