webbjeepxj Posted March 30, 2011 Share Posted March 30, 2011 So I want to run 37s on my XJ, I have been collecting parts for a while and have tons of stuff, except the Axles ........ Can someone help me with this ....... http://washingtondc.craigslist.org/mld/ ... 50224.html Anyone use their ID skills, would these be a good set? they look like 16 inch wheels, 8 lug .... Anyone have any insight? Thanks! Link to comment Share on other sites More sharing options...
webbjeepxj Posted March 30, 2011 Author Share Posted March 30, 2011 I realize I already have wheels ........ prob should have waited on that ........ 5x4.5 Anyone run 37s on stock XJ dana 44 rear? ..... I'm assuming thats the best option and pair it with a 44 in the front. I'm light footed. Link to comment Share on other sites More sharing options...
mkbruin Posted March 30, 2011 Share Posted March 30, 2011 Jeep never had a 60 front in any model. Its probably a J20 set, HD44 front, 60 rear. Its also passenger drop, so it won't fly unless you do a d300 swap edit: There was a closed knuckle 60 front in the Kaiser M715/725, but this set is an open knuckle, which rules out any Jeep facroty 60. Link to comment Share on other sites More sharing options...
Sir Sam Posted March 30, 2011 Share Posted March 30, 2011 Jeep never had a 60 front in any model. Its probably a J20 set, HD44 front, 60 rear. Its also passenger drop, so it won't fly unless you do a d300 swap edit: There was a closed knuckle 60 front in the Kaiser M715/725, but this set is an open knuckle, which rules out any Jeep facroty 60. Yup my thoughts as well. Link to comment Share on other sites More sharing options...
webbjeepxj Posted March 30, 2011 Author Share Posted March 30, 2011 Thanks! Yea, I'm going to do some more research on the FSJ stuff, Honcho, Gladiator etc. but I'm kind of thinking just sourcing the XJ 44 since it seems pretty bolt-in-able. Link to comment Share on other sites More sharing options...
mkbruin Posted March 30, 2011 Share Posted March 30, 2011 Thanks! Yea, I'm going to do some more research on the FSJ stuff, Honcho, Gladiator etc. but I'm kind of thinking just sourcing the XJ 44 since it seems pretty bolt-in-able. Are you looking for a front, rear, or both? The FSJ's came with terrible gear ratios from the factory. Unless you are going big and need 4.56 or better gears, they aren't worth the time. Also, you will have issues with bolt patterns. For just a rear, I would look at xj/mj 44's, mj model 20, or ford 8.8 Link to comment Share on other sites More sharing options...
