Brakes hanging up
Ive had problems with my rear right shoes in the past but just yesterday it got persistent and now it seems like its stuck against the drum. I'm opening it up on thursday and got my own idea whats happening but just wanted to get all your opinions. Thank you :bowdown:
If I understand you correctly, your issue is that
the shoes do not return to the non-braking position
after applying and releasing the brake pedal.
Things to consider, or rule out:
1) bad wheel cylinder (sticking piston)
2) incorrect shoe or spring installation
3) shoes worn crooked due to #2
4) EB cable frozen and not fully releasing
I had the same problem with my chevy c10 check you rubber brake line if their old it will push brake fluid to the brakes but when it mater cyl. tries to suck the fluid back to the reservoir to release the brakes, the rubber hoses collapse causing the brakes not to release or lock up.
