STERLING STINGER Posted March 22, 2011 Posted March 22, 2011 i think this is the outer axle ... its on the passengers side and it connects to the universal to the bearing.. oh yeah, its for my 88...its grounded until i get this part i will pay instantly it was welded , not by my approval....it lasted all winter plowing...now snap..... i have a new universal and the bearing is only 3 months old..just need the axel i tried to reweld it, but I'm not gonna run it like that...its not me..
STERLING STINGER Posted March 23, 2011 Author Posted March 23, 2011 noone got one of these laying around?
STERLING STINGER Posted March 24, 2011 Author Posted March 24, 2011 anyone at least know what the part is called / outer axel?
mnkyboy Posted March 24, 2011 Posted March 24, 2011 Its called a stub shaft,just make sure you get one that uses the correct size u joint you probably have the 260 joints. You might also try to find an XJ in the junk yard they are the same,you could also try to find a set of later or ABS axle shafts so you can get the 297 u joints
