part needed ....outer axle...instant payment...
STERLING STINGER
i think this is the outer axle ...
its on the passengers side and it connects to the universal to the bearing..
oh yeah, its for my 88...its grounded until i get this part
i will pay instantly
it was welded , not by my approval....it lasted all winter plowing...now snap.....
i have a new universal and the bearing is only 3 months old..just need the axel
i tried to reweld it, but I'm not gonna run it like that...its not me..
Its called a stub shaft,just make sure you get one that uses the correct size u joint you probably have the 260 joints.
You might also try to find an XJ in the junk yard they are the same,you could also try to find a set of later or ABS axle shafts so you can get the 297 u joints
