Scott86mj Posted December 15, 2006 Share Posted December 15, 2006 How much drop will it give over the stock mj pitman arm? and would it be ok for 5.5" re springs or do I need to get a aftermarket one. thanks in advance Scott Link to comment Share on other sites More sharing options...
Eagle Posted December 15, 2006 Share Posted December 15, 2006 About an inch drop. Link to comment Share on other sites More sharing options...
DirtyComanche Posted December 15, 2006 Share Posted December 15, 2006 You drop it, you have to drop the track-bar. Link to comment Share on other sites More sharing options...
Eagle Posted December 15, 2006 Share Posted December 15, 2006 You drop it, you have to drop the track-bar. True. If you don't keep them parallel, you get bump steer. Link to comment Share on other sites More sharing options...
Bounty Hunter Posted December 15, 2006 Share Posted December 15, 2006 I use the stock pitman arm with RE 5.5" springs, no problems. Like said, the ZJ arm drops about 1" lower than the MJ/XJ arm. Link to comment Share on other sites More sharing options...
Scott86mj Posted December 16, 2006 Author Share Posted December 16, 2006 I'm getting the control arm drop brackets and re track bar. Will that have any drop to it? Also I was looking at the mj extreme duty 5.5 and it said it comes with a 1.75" coil spring spacerand the 1345 springs. So how much lift do you actually get. I already have a set of coil spring spacers should I install them to? I'm only running 31s right now but am setting it up for 34s or 35s when I get some lower gears. I have the rustys lower adj arms and stock uppers. Will I have to get uppers to get that much lift? thanks Scott Link to comment Share on other sites More sharing options...
