I am gearing up to put my Dana 44 in my 1991. I know I'll need some new 2.75x8x9/16 U-bolts and to have my driveshaft shortened 1". What I need to know now is whether I will need to source new spring plates?
I can reuse the Dana 35 ones? I don't have Dana 44 ones from the parts MJ.
I reused them from my D35 axle. They are the same p/ns for either axle and all springs, including my MT springs. Don't know if you have a LWB or SWB, but in either case they will work, you just swap sides with the plates because of the difference in the shock mounts. If you use 9/16" u-bolts you may have to drill them out though. I used 1/2" u-bolts.
I'm pretty sure the holes are elongated so the same plates work with both axles.
The stock plates will NOT work with the Chrysler 8-1/4 axle, though.
RE: "The stock plates will NOT work with the Chrysler 8-1/4 axle, though."
I must have gotten lucky because my stock plates on the original D35
worked beautifully on the Chrysler 8.25 swap. The original holes were
enough to accept the wider 3" diameter U-bolts. I confirmed this was
not an oddity after ruining one of the shock stud threads and hunting
all over Texas for a replacement plate. That plate also fit the 8.25 just
fine.
