smg1986 Posted February 25, 2011 Share Posted February 25, 2011 1986 comanche is having radio issues. it used to work fine now all that comes through is static. Any thoughts? also what temp thermostat is best with the 2.5 Link to comment Share on other sites More sharing options...
jimoshel Posted February 25, 2011 Share Posted February 25, 2011 20 year old radios get dirty and corroded. The fact you hear static says the speakers and associated wiring are OK, unless it's the speakers themselves gone bad. You have 2 connectors in the antenna lead. One entering the radio and one by the kick panel. Clean them. Remove the radio and remove its cover. Spray the volume control with electrical contact cleaner. Get a new radio. 190 thermostat. Link to comment Share on other sites More sharing options...
jons87mj Posted February 25, 2011 Share Posted February 25, 2011 i had the same thang happen to me :headpop: all was good so i checket the radio anttina plug and seen the plug was broke sodered it all back and works fine now :yes: Link to comment Share on other sites More sharing options...
Dirteatr717 Posted February 25, 2011 Share Posted February 25, 2011 I only had one station until I did this: Take off the pss kick panel, disconnect the antenna connection, remove the spring and then tape the connection back together like so Good luck :cheers: Link to comment Share on other sites More sharing options...
