I had rotted forward window channel seals like alot of you do. So i decided to do something about it. Simply removed the bad channel seal down to just below where it comes out of the door,cleaned the area where it was with rubbing alcohol,and used stick on weather strip that can be bought at a hardware store. Put it on the left,and right sides of the forward channel not the back.here is a pic if the link will work. :cheers:
Yes much cheaper. I used 5/16" x 1/4" seal size by the way ,but 5/16 x 5/16 would provide a tighter seal against the glass if that size is available. :dunno:
