neverstuck Posted February 15, 2011 Share Posted February 15, 2011 1988 Jeep Comanche Metric Tonne 119,500 miles Originally a D44 in the back with still A chrysler 7.25 in the front. (D30) but has 7.25 stamped on it. 6 cylinder, auto trans, column shift, stock in cab brake controller for prop valve in the rear. (btw, when i did the exhaust manifold it had CJ stamped on the the engine block) 24.6 Gallon stock fuel tank. Also stock hitch. ******Original Comanche Bedliner******It says Comanche in the front :) (Taken out n being saved) Drive it for fun or in the snow, 29x10.5 super swamper xs's; long travel shocks in the rear Just did new injectors/rail/fuel pump/filter/regulator/plugs fixxed all vacuum leaks The motor, trans, and t-case are good the current axles need to be swapped out(I'm looking for a d30 and a have an 8.25 laying around) Just took it thru inspection last week. Passed everything, including running emissions,except idle emissions so i failed. :grrrr: Ive owned the truck since 2005, bought it off an older gentleman that used it for hunting. (Bout it for 5, put 5k into it) Located in the Southern New Jersey Pine Barrens Owned by N. Brown of EHT Link to comment Share on other sites More sharing options...
neverstuck Posted February 26, 2011 Author Share Posted February 26, 2011 Front axle replaced with a non-disco axle; had to swap knuckles/hub bearings from the original d30 so my brakes would work. plugged vacuum lines and all is well. Rear axle being replaced asap. with 8.25. Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 24, 2019 Share Posted May 24, 2019 Build date: 6/28/88 Link to comment Share on other sites More sharing options...
jdog Posted June 25, 2020 Share Posted June 25, 2020 BODY JL62 *X3 DESCRIPTION NOT AVAILABLE -SA Charcoal AGC Black Ram 1500 Sport Group APA Monotone Paint AWJ Visibility / Protection Group CBA Straight Back Bench Seat CGX RR Head Restraints Outboard Seating DGW 4-Spd. Automatic 4RE Transmission DTA DESCRIPTION NOT AVAILABLE ERB 3.6L V6 24V VVT Engine GAC Tinted Glass Windows GEC Front Left Side Sliding Window GFD Rear Sliding Window GTZ Manual Remote Mirrors JJA Cigar Lighter LMA Halogen Headlamps MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket NAA Federal Emissions NFA 20 Gallon Fuel Tank PE4 Colorado Red QE4 Colorado Red RAB AM/FM Radio SBA Power Rack and Pinion Steering SUA Tilt Steering Column TBB Full Size Spare Tire WJD 15X7.0 Styled Steel Wheels Z5B Payload Rating - 1800# Link to comment Share on other sites More sharing options...
jdog Posted March 6, 2021 Share Posted March 6, 2021 Selling Dealer: ISLAND MOTORS INCORPORATED Manahawkin, NJ Link to comment Share on other sites More sharing options...
