ORCA Posted December 7, 2006 Share Posted December 7, 2006 Anyone have a write up on how to align your own steering? I've seen them floating around but can't locate any. :roll: Any help is appreciated! :cheers: I put in my v8 ZJ steering components today and floating off to the side of the road :eek: (pics: http://www.comancheclub.com/forums/view ... 5642#25642 ) Link to comment Share on other sites More sharing options...
Oizarod115 Posted December 7, 2006 Share Posted December 7, 2006 basically. loosen up the adjuster sleeve, measure the distance between the back of the tires, then measure the distance between the front of the tires, and adjust it until they are 1/8" toed in which means the fronts are closer than the backs of the tires. you can use a pipe-wrench to turn the tie-rod in order to adjust it. then use the adjuster sleeve on the draglink to adjust the steering wheel to center (while the tires are facing pretty damn close to striaght ahead) Link to comment Share on other sites More sharing options...
ORCA Posted December 7, 2006 Author Share Posted December 7, 2006 Awesome, thanks. I'll be at it tomorrow Link to comment Share on other sites More sharing options...
Eagle Posted December 7, 2006 Share Posted December 7, 2006 You need Marcus (a.k.a. GoJeep). http://gojeep.willyshotrod.com/HowtoAlignment.htm Bookmark his site -- he has a wealth of XJ information on there, and a lot of it will translate over to the MJ. Link to comment Share on other sites More sharing options...
ORCA Posted December 7, 2006 Author Share Posted December 7, 2006 http://gojeep.willyshotrod.com/HowtoAlignment.htm There it is.... Thanks Eagle :bowdown: Quick question: I see in markus' write up that he adjusts the alignment while the jeep is on the ground, is this the proper way to do it? I was thinking of jacking it up to put less stress on the adjusting sleeves - or am i crazy? :nuts: Link to comment Share on other sites More sharing options...
Bounty Hunter Posted December 7, 2006 Share Posted December 7, 2006 On the ground. Camber moves slightly between on the ground and in the air. The toe will change if the suspension is unloaded, screwy XJ/MJ/TJ thing. Link to comment Share on other sites More sharing options...
ORCA Posted December 7, 2006 Author Share Posted December 7, 2006 On the ground. Camber moves slightly between on the ground and in the air. The toe will change if the suspension is unloaded, screwy XJ/MJ/TJ thing. Roger that. Thanks man Link to comment Share on other sites More sharing options...
87manche Posted December 7, 2006 Share Posted December 7, 2006 screwy y link steering setup. Link to comment Share on other sites More sharing options...
500 MJ Posted December 7, 2006 Share Posted December 7, 2006 And you know that you loosen the sleeve on the drag link and adjust that to get your steering wheel to be straight if you lift it. Link to comment Share on other sites More sharing options...
Eagle Posted December 8, 2006 Share Posted December 8, 2006 I was thinking of jacking it up to put less stress on the adjusting sleeves - or am i crazy? :nuts: Not really a problem, but if you're working on a concrete floor, just sprinkle some speedy dry where the tires will be before you pull the vehicle into position. The speedy dry will act like little ball bearings and allow the tires to "scrub" easier on the concrete. Link to comment Share on other sites More sharing options...
