koooooooz Posted December 6, 2006 Share Posted December 6, 2006 ok i got the mj stock and it was sagging in the front Image Not Found i decided to lift it i was going to go wit 3 inch coils and 2 inch shackles when i got the coils on i let it sit and well i think it sits level i was going to put a buget boost (2inch coil spacers and 1and a half inch shackles) i just don't no if i will need new arms if anyone could give me a height from the grown to the finder of a stock MJ in front and back and then the mesurements from the grown to the finder of a mj lifted 3 inches ooh here is it now lifted 3 inches in the front Image Not Found Link to comment Share on other sites More sharing options...
feerocknok Posted December 6, 2006 Share Posted December 6, 2006 My bed's level to an 1/8 of an inch. 4.75" front, 2.25" rear. I've got 3" coils and 1.75" spacers. I replaced my LCAs with the bent adjustable arms, but they still hit my LCA mount allowing the axle to only travel a small amount downward. With different upper arms, I could rotate the axle, rotating the mounts so the LCAs would clear. With my particular experience, I Needed new lower control arms, and Want new uppers. Drop Brackets may be a good route for you to go though. Link to comment Share on other sites More sharing options...
Pete M Posted December 7, 2006 Share Posted December 7, 2006 Measurements from the ground to the fender won't be on much help since the tires will likely be of different sizes between different trucks. Measurements from the center of the wheel to the fender would be more helpful. :D Link to comment Share on other sites More sharing options...
koooooooz Posted December 7, 2006 Author Share Posted December 7, 2006 ya thanks i did not think of that Link to comment Share on other sites More sharing options...
