one more tranny swap question
dirteater717 is correct an ax5 out of a 2wd as the splines count and output ahfts are different from the 2wd to 4wd, however i once came across a write up on putting an ax15 out of a dodge dakota in but not to sure as a direct bolt in you will need an ax5
I'm pretty sure you would need to look for a 2wd ax-5 :hmm:
Someone else will Chime in
