driveshaft removal
ever picked up a 2wd MJ driveshaft? the ones with the rubber isolator? :D thems heavier than they look. :yes:
but regardless, I was thinking more along the lines of damaging the u-joint if it fell to the pavement.
Would recommend marking the orientation of the driveshaft ears to the yoke before removing as some are balanced better one way than the other. Just mark on one side with chalk a line so you can line it up afterwards. I mention this as after i removed mine to replace the rear u-joint I just put the shaft back in. Made an aweful howling, took bolts out rotated 180 and reinstalled, noise gone. :wrench:
