I'm soon going to be swapping my 88 2wd to 4x4. Its currently a renix 4.0 an 2wd AW4. I plan on using my 90 renix 4.0 compleat drive train. But my donor is a 90 with a ax15 tranny. I would like to keep my swaped truck a auto aw4. What year trannys will work with my current 1988 wiring? I do know the renix has a bell housing CPS. Is it as easy as swaping on the renix 87-90 bell housing on any AW4?
If you get a 4 cyl one ('87 up), you can swap the 6 cyl bell, but it's not quite as strong.
Get a matching pair trans/tcase from '87 to '96 and they will work. Mismatching means you need 21 spline to '90 and 23 spline '91 up on the 6 cyls.
That just controls the computer. You can even wire up newer AW4s to run like that (program is already in them. Just the wires weren't included)
