DIY SYE....
Show me what you've got.
I am thinking going hack'n'tap, without the hack. Just tapping, adding the new flange, new seal, and running it. No real need to hack since we have long enough wheelbases to start.
So... who's running what?
The reason for the hack is to eliminate stress on the output seal. You will roach the output shaft if you do not shorten it.
You want as little stress behind the seal as possible.
With that being said...I have seen writeups on NAXJA with part numbers for HNT SYE's.
