i was lookin for a ax15 and the tcase, but just learned that the ba10/5 is geared a little lower? is it?... if thats true i may just get another ba10 or rebuild mine stronger..
You can't build a Ba-10 any stronger. The case itself is weak. If you're looking for a lower first gear, I think the newer 3500 and 3550 may be what you're looking for. First gear for the AX-15 is 3.83 and I believe the 2550 had a 4.04 or something like that. The NSG 370 six-speed has a 4.46. :D
are the expensive and hard to find?????
The 6-speeds have only been around a couple years now, so yes.
