btm24 Posted January 12, 2011 Share Posted January 12, 2011 Hey I'm just about ready to install Every thing that I have gathered over the past few weeks/months. One of which would be the ford 8.8 rear axle. I was told that install the axle in my truck it would be much easyer to get new shock "tabs" or "mount"s. How ever I don't know any car part stores that carrys them. So where would I look for some new shock mounts? And do they sell them in sets or as one at a time? Thank you very much. Brandon Edit: idk if this matters or not but I will also be installing a 4.5" RC lift kit when I go to put the axle's in. Link to comment Share on other sites More sharing options...
kyleag89 Posted January 12, 2011 Share Posted January 12, 2011 Are you talking about these? http://rustysoffroad.com/mm5/merchant.mvc?Screen=PROD&Product_Code=JKS-9604&Category_Code=SUS_ACC Lift shocks don't come like the factory Jeep ones with the dumb bar going through one end. Link to comment Share on other sites More sharing options...
mnkyboy Posted January 12, 2011 Share Posted January 12, 2011 Most people just make shock mounts but you should be able to use the factory ones. The factory mounts just bolt on under the springs. Link to comment Share on other sites More sharing options...
btm24 Posted January 12, 2011 Author Share Posted January 12, 2011 never mind he did not know that they were bolted on not welded. I'm sorry I will be able to use the ones that are allready on there. thanks Brandon Link to comment Share on other sites More sharing options...
mule13 Posted January 13, 2011 Share Posted January 13, 2011 Brandon, Theres a store in Ocala/Bellview called performance 4x4 (i think) that has all that kind of stuff. they also have used gear sets etc and new sets. they carre shock mounts and spring perches. if they don't have it they can tell you where to get it. its right on the side of 441 just before ocala.theres also a decent jy right before them called marks that usually has alot of xj's in there. last time i went they had a mj in there too that was around christmas.i bought a transmission crossmember with the mount for 12$. John Link to comment Share on other sites More sharing options...
btm24 Posted January 13, 2011 Author Share Posted January 13, 2011 wow very good thanks for that. but Ocala is like 2hr's away :( Brandon Link to comment Share on other sites More sharing options...
